Autohub Magnet and Service...
- Statey
30 Aug 2016 15:45 #171863
by Statey
Autohub Magnet and Service... was created by Statey
I've just taken my Autohubs off as need to do the CV and bearings and the hub itself was in a poor state
I've cleaned it up and it moves freely but according to the manual there's a magnet that holds it in the released position should it hold it when off the car or is it only when the airlines are attached?
Don't know if it's knackered as it won't stay pushed in held by the magne?? Anyone played with there's before?
Also how much grease do people recommend to pack it with?
- Colander
31 Aug 2016 19:51 #171898
by Colander
Replied by Colander on topic Autohub Magnet and Service...
Looks like that needed doing! They should rotate freely when off the car. Assuming you have completely degreased it, I'd make sure it's well greased and that there's no friction when rotating. Don't pack the whole hub with grease though
- Statey
31 Aug 2016 23:28 #171904
by Statey
Replied by Statey on topic Autohub Magnet and Service...
It should rotate??? Now I am confused
01 Sep 2016 18:48 #171918
by facade
Replied by facade on topic Autohub Magnet and Service...
The star shaped lump with the internal splines pushes inwards, locks and then the lump will rotate (actually it stays still with the driveshaft whilst the black outer hub rotates)
If you pull & twist it, it springs outwards until the teeth on the outside lock into the big flat washer and the hub drives.
By the state of yours the teeny weenie air passages in the hub will be blocked, check you can blow through the two spigots whilst you have the hub off.
No doubt one of the many people who took theirs off to fit manual hubs will have a working pair that they don't need.
- Statey
01 Sep 2016 21:11 #171920
by Statey
This is why I was confused!
My magnet seems to be dead and not locking at all. Thankfully I got another set for the cost of postage
This is what happened...
- auchenblae
- Elite Member
- Thank you received: 25
05 Sep 2016 13:14 #172019
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Autohub Magnet and Service...
Yes they need replaced.
I cannot understand what happened to the magnet?
I'm going to guess the calipers have been siezed and boiled the grease in there and probably in the hub bearing and you may well have clogged vacuum passages in the knuckle hub due to this.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 1.772 seconds
