Varying air-conditioning performance
- MrMarwanH
Car temperature is normal, I can see and hear the compressor working, and its a f**king new car, please help.
- Thank you received: 1983
- MrMarwanH
11/60 wrote: Yours is the one that sat unused for best part of a year before you bought it in a different country. Have you had it regassed or more importantly had a specialist look for leeks? Im only guessing but if it has been sat in either the open air or worse an unclimate controlled shed the kind of scorchio temperatures you have will not have been good for the seals if they have effectively dried out from no use and lots of heat? Possibly?
I thought about gas leak, however sometimes its extremely cold, sometimes its not, so I guess its not a gas problem
1- It is normal for jimny here in middle east
Suzuki ac compressor is bad not only for jimny also for vitara and swift
Suzuki Owner in U.A.E they replace the ac compressor With Toyota corolla compressor
2- If you need to increase air-conditioning performance you need cover the Ac pipe spicily the pipe that front of the engine head to the ac compressor
many reason
1- Heat transfer from the engine head to the pipe
2- Heat transfer from the radiator hose to the pipe
3 - hot air come from engine fan
