1inch body lift kit question!
  • fransolis94
12 Jul 2016 03:41 #169902 by fransolis94
1inch body lift kit question! was created by fransolis94
hi guys!! my jimny has a 2 inch suspension lift kit, if i wanted to add a 1 inch body lift kit to my jimny do i have to change or modified something?? or just install on the body lift kit?? thanks! :)
12 Jul 2016 04:30 #169904 by Lambert
Potentially lot's like brake pipes, steering column, gear lever clearance, wiring. Depends on how high you go? It is also going to raise the centre of gravity of the car and whilst it may allow you to fit marginally bigger tyres unless you do it won't really give you any more ground clearance under the axles.
The following user(s) said Thank You: fransolis94
12 Jul 2016 04:54 - 12 Jul 2016 04:55 #169906 by X8GGY
Replied by X8GGY on topic 1inch body lift kit question!
I've got a 1.5" suspensino lift and a 1" body lift in order to get 235/75/15s onto my "daily driver" build -
www.bits4vits.co.uk/store/daily-driver-jimny/blog_340.html
You can see on my blog what's involved...
Dave ;)
Last edit: 12 Jul 2016 04:55 by X8GGY.
Time to create page: 0.643 seconds
