Jimny Cruise Control Question.
- johna
28 Aug 2016 09:24 #171787
by johna
Replied by johna on topic Jimny Cruise Control Question.
you have 2 wires for the magnet sensor. black and blue/black.
what wires on the Jimny did you tap into
. did you cut the speedo wire and then connect the 2 wires to either end or are there 2 wires that you just tap onto.is the speedo wire the green and yellow wire that comes from the transfer box.
I have one fitted up to this point but i don’t really want to connect the magnets to the tail shaft, its to exposed.
john
john
- WailingJimny
28 Aug 2016 12:26 #171796
by WailingJimny
Hi Folks, I like the sound of this option, especially as I live in the flatlands of Cambridgeshire. As my vehicle is still under warrantee, do you think the dealers would see it as a problem ?
Replied by WailingJimny on topic Jimny Cruise Control Question.
gilburton wrote:
If that is too complicated or expensive for you they also do a cheap "cruise control" but it's not a true cruise control as it just sets the throttle and won't adjust on hills like the other one will.
Might be handy for ploughing fields though?? :laugh: :laugh: :laugh:
www.conrad-electronic.co.uk/ce/en/produc...rol?ref=searchDetail
- Crumbs
28 Aug 2016 12:35 #171798
by Crumbs
Replied by Crumbs on topic Jimny Cruise Control Question.
I've installed the AP500 and my Jimny is still under warranty.
My Suzuki agent know what I have done and they have not raised any objections.
I replied to Johna this morning but it hasn't appeared. Do moderators hold postings back until approved?.
- Crumbs
28 Aug 2016 13:10 #171799
by Crumbs
Hi Johna,
Post went missing this morning, so this is a second try.
The magnets on the propshaft wouldn’t last long in an off road vehicle.
We took the option to get the road speed sensor from the out sensor on the side of the gearbox. That sensor has been used for cruise control for the past 16years to my knowledge. You can also get the road speed from the back of the console. The gearbox is easier to get at but you have to make sure that the wire is properly anchored to prevent swinging about in the wind.
Because the Jimny is only two years old, all the connections were soldered at the sensors etc. No cables were spliced into to avoid potential problems with the ECU checking resistance and reporting faults.
Is yours an automatic or manual Jimny?
The manual gearbox needs a clutch switch and an over revving preventative function using the engine RPM, the automatic needs neither.
However an automatic like mine does have the potential to over rev if the AP500 is giving it full throttle at motorway speeds and the motorway gets so steep that the gearbox drops down a gear the kickdown kicks in and the engine revs it’s head off.
Are you installing an AP500? Have you got the instructions?
- Crumbs
28 Aug 2016 13:13 #171800
by Crumbs
Does anybody know if the settings of an AP500 control module can be read by a connected laptop or other device?
- johna
29 Aug 2016 10:15 #171832
by johna
I have a AP60 which is vacuum activated and the vehicle is a 2003 manual It comes with the clutch switch which is all fitted . and according to the installation instructions the red led on the control unit says its all ok.As i removed the vacuum hubs and replaced them with the manual ones i used the vacuum tank that is already installed.
There are 3 wires coming out of the sensor on the gearbox which i have traced to the passenger side floor , under the speaker, a perfect place to connect to. 1 wire is black with orange stripe ,1 wire is green and yellow, 1 wire is blue and black.
The wires on the controller. 1 wire is blue and black , 1 wire is black.
what i need to know is what wire is connected to what. Can you see which one is connected to which on your car or is it all covered with tape.
john
john
Time to create page: 0.275 seconds
