Engine Misfire After starting the car ( video)
13 Jun 2016 23:28 - 13 Jun 2016 23:40 #168504 by Mr.m.y
Hi
The problem is my car start Misfiring After starting the car
It Misfire for 30 sec or if i rev the car to 2 rpm it stop misfiring
When it Misfiring i put int reverse it be worst
Then it come normally
www.dropbox.com/s/zzoxjp70dckehhm/17c7ef...baefd57aa68.mp4?dl=0
Any help or recommendation
Last edit: 13 Jun 2016 23:40 by Mr.m.y.
  • mickt
15 Jun 2016 09:59 #168601 by mickt
Link not working!
15 Jun 2016 13:14 #168607 by McVicar
Works for me. Can't help though sorry.
  • Ryder666
15 Jun 2016 22:47 #168648 by Ryder666
Replied by Ryder666 on topic Engine Misfire After starting the car ( video)
Try replacing the engine temp sensor could be that it has failed and not giving the correct fueling for initial start up. Or worth making sure plugs haven't fouled up with the poor running
Tom
16 Jun 2016 12:26 #168661 by kirkynut
There could be many reasons for this.
I would check the basic first, like the spark plugs. When were they last changed? What condition / colour are the electrodes now?
If the air filter full of dirt making it run richer as less air can get in?
Is the car using any coolant? If so it could be a failing head gasket and you are burning off the coolant that has seeped into the combustion chamber.
It could be a sensor such as the coolant / oil temperature sensor, whichever the Jimny has.
As I say, check the basic first and eliminate them.
The following user(s) said Thank You: Mr.m.y
16 Jun 2016 23:30 #168699 by Mr.m.y
Thank you all
Time to create page: 0.174 seconds
