235/75/R15 Will Fit in Jimny lifted 2 Inch ?
20 Apr 2016 07:33 #165515 by Mr.m.y
Hi
2013 Jimny, LHD, 205/70/R15
I am planning to fit 235/75/R15 tyre
The questions are ?
It will fit ??
it need a spacer ?
Trimming ?
I should change the Rims ?
Thank you
20 Apr 2016 21:49 #165553 by Busta
It will need trimming. Ideally you need wider rims but they will fit ok on standard ones. Spacers will make them rub more.
The following user(s) said Thank You: Mr.m.y
  • idiotmobil
21 Apr 2016 16:27 - 21 Apr 2016 16:28 #165580 by idiotmobil
Replied by idiotmobil on topic 235/75/R15 Will Fit in Jimny lifted 2 Inch ?
Also need to think about gearing as that will be crap as well
Last edit: 21 Apr 2016 16:28 by idiotmobil. Reason: Spelling
22 Apr 2016 10:39 #165626 by Mr.m.y
What about the gear ?
22 Apr 2016 16:26 #165637 by Busta
Taller tyres increase the overall gear ratio and make the car sluggish (like always being in the wrong gear). This can be corrected by changing the gears in the transfer case, diffs or swapping to a different transfer case.
Time to create page: 2.905 seconds
