Strange noises in 1st an 2nd gear
- Bulldog94
06 Feb 2016 08:47 #161946
by Bulldog94
Strange noises in 1st an 2nd gear was created by Bulldog94
When am in 1st or 2nd gear there's something not right sounds like something is wobbling round and hitting something? But it's only in 1-2 gears rest are fine?
Any help would be good thanks ðð»
06 Feb 2016 09:15 #161949
by Busta
Replied by Busta on topic Strange noises in 1st an 2nd gear
Check the rear engine mount. It's at the back of the gearbox. If you lay under the car and can lift the back end of the gearbox the mount has failed.
06 Feb 2016 10:04 #161953
by facade
Replied by facade on topic Strange noises in 1st an 2nd gear
Mine made a sort of graunchy howl when accelerating hard in 1st, that I thought was a bearing failing in the gearbox as I could feel a slight vibration through the gearlever.
It was the crankshaft pulley outer separating from the inner, and wobbling about.
Never did it at 70 plus in top gear though, when the engine was at the same sort of speed...
Time to create page: 0.159 seconds
