A metal 'tube' that broke off under the jimny
  • Awiz
31 Jan 2016 21:12 #161598 by Awiz
Ok so I'm going to need to have some welding done in any case. Though at this point I still don't understand how this rod is a part of the gear changing.. :)
By the way, I was able to drive it normally, only did less than a kilometer, but still. 4H and 4L working just fine, didn't change up to 3rd gear though, 1st and 2nd worked as usually. If i recall correctly.. Jimny has been sitting for over a month at this point.
31 Jan 2016 21:16 #161599 by j999pre
The gear linkage has 2 rods. One that moves and one that is solid, the steady rod. This is what has snapped on yours. When it did on mine the gear change was just a bit sloppy and that rod was rubbing on the transfer box propshaft.
Grey pick up Jimny
  • Awiz
31 Jan 2016 21:23 #161601 by Awiz
Thanks for your quick responses. This seems clear to me now. I'll try to get it welded somewhere, as I don't happen to have the equipment of my own..
What kind of a sound would your rod make when it rubbed the shaft? Like some grinding or? This one does a really loud, sharp clicking noise which got us worried and we didn't want to drive it anymore.
Cheers, appreciate your help.
  • Dave cc
02 Feb 2016 20:39 #161748 by Dave cc
Replied by Dave cc on topic A metal 'tube' that broke off under the jimny
Had one go on a Jimny yesterday clean it up burn it back on with a mig seems to be common done 3 now
  • Awiz
03 Feb 2016 09:00 - 03 Feb 2016 09:03 #161769 by Awiz
Right, thanks. I guess someone should do some engineering and figure out a better way to attach it. A stronger mount. Wonder if it had any influence on the operating of the gearbox if this end of the rod was attached a bit closer to the ground than it originally is..
Ah, Dave, what parts did you take off the jimny to make room for the welding, perhaps the gearbox-transfer case shaft?
Last edit: 03 Feb 2016 09:03 by Awiz.
  • pharllap
12 Feb 2016 21:22 #162303 by pharllap
Replied by pharllap on topic A metal 'tube' that broke off under the jimny
Doing mine this weekend, I'm planning on taking mine off to weld.....
This is mine 2001 model
Time to create page: 1.682 seconds
