Need new engine XP any advice?
  • George.
25 Dec 2015 16:04 #159094 by George.
Replied by George. on topic Need new engine XP any advice?
Its the softtop but I think there the same engine or it should at lest fit, what sought of condition is the one you've got, milage etc thanks
  • George.
25 Dec 2015 16:05 #159095 by George.
Busta wrote: If its an m13a (twin cam, dohc on the engine cover) I have one available in Norfolk.
Do you have a number I can contact you on?
25 Dec 2015 17:00 #159096 by j999pre
You need a g13b. With a crank sensor in the sump.
M13a won't do
Grey pick up Jimny
  • idiotmobil
25 Dec 2015 17:22 #159097 by idiotmobil
Replied by idiotmobil on topic Need new engine XP any advice?
Check that as I had a soft top and engine was original and was exactly the same as the hard top were sensors were concerned I found out there are a few but not many this way
25 Dec 2015 17:46 #159098 by j999pre
Yes check as someone could have swapped the wiring loom and ecu and fitted a non crank sensor one.
Or it could be a late registered early soft top which did not have the crank sensor. They stopped about w reg.
Grey pick up Jimny
25 Dec 2015 18:38 #159100 by Busta
Mine won't fit, sorry. I'm breaking a soft top ( minus an engine) if you need any other bits though.
