How fast should the thermostat open?
  • Gerula
08 Dec 2015 12:56 #158096 by Gerula
How fast should the thermostat open? was created by Gerula
As it happens when you start doing small repairs yourself, you end up with the "maybe I should also do this" syndrome :laugh:
So I started to wonder if the thermostat in my Jimny (G13BB engine) isn't opening a bit slow. With outside temperatures just above freezing, it needs a full 5 min drive (town) to get the dash temp gauge in mid-level position and maybe another 2 mins to get the heater to blow hot air. That happens in the morning with a cold engine.
I'm thinking that it should be able to deliver hot air inside the cabin much faster? What is your experience in similar outdoor temperatures?
  • Gerula
08 Dec 2015 14:03 #158099 by Gerula
Replied by Gerula on topic How fast should the thermostat open?
Problem is that it's not very cold now :) , this morning I had about 5 degrees Celsius outside my house .
On other cars I've had I remember that the engine temperature was rising quite faster, maybe 2-3 minutes in late November - early December, when outside temperature was a few degrees above freezing.
All this with cabin radiator closed, of course.
  • Gerula
08 Dec 2015 15:36 #158106 by Gerula
I said "on other cars I've had" :) (which is a lot of cars during the last 25 years).
When was the last time you changed the thermostat? Yours may be on it's way out as well, 5 mins when outside temp is 20 C seems a lot.
  • Gerula
08 Dec 2015 16:24 #158108 by Gerula
Thank you, this means that on the 88 C thermostat it would be normal to see the gauge get to working temperature in about 5 minutes.
If others have different experiences please share :)
09 Dec 2015 01:25 #158152 by kirkynut
My 2000 twin cam warms up pretty quickly and is quite warm within a few miles to 89'c which it sits at for most of the time unless under strain on a long motorway hill when it might creep to 94'c.
I have a scangauge so can monitor it to the degree.
09 Dec 2015 08:10 - 09 Dec 2015 08:12 #158161 by Busta
Mine starts blowing hot air before the gauge gets to the middle. I'd say hot air in 3 minutes, gauge levels out at 5 minutes. That's a M13a, driving straight onto fast country roads. 5 minutes doesn't sound preposterous though. Ever driven a Landrover Defender? By the time the heater starts to work it's summer again.
Last edit: 09 Dec 2015 08:12 by Busta.
The following user(s) said Thank You: Gerula
Time to create page: 0.281 seconds
