Hi, Small oil pool on the left side of the engine.
  • BenoMosko
29 Nov 2015 10:16 #157453 by BenoMosko
I'm curious if it's something i need to be concern and taking care of - Attaching Pictures.
29 Nov 2015 10:42 #157457 by facade
That will be the cam cover gasket: needs a new one, and carefully torquing the fasteners. If you over tighten them to stop the leak, the cover distorts and leaks more.
Check that the black hosepipes leading to the top of the engine, and the grey valve by the dipstick are not blocked up.
I'd give it a little squirt of gunk, and wash it off personally (actually, I wouldn't bother :whistle: any oil running down the engine will help stop the sump going rusty ;) )
The following user(s) said Thank You: BenoMosko
  • BenoMosko
29 Nov 2015 11:17 - 29 Nov 2015 11:23 #157461 by BenoMosko
Thank you for your reply, much appreciate.
So, by reading your comment,
It's a known issue that don't need to bother me at all, Fix me if I'm wrong.
What exactly should i need to tighten? cam cover gasket (What is that?)
and how can i check that the black hosepipes leading to the top of the engine are not blocked?
should i contact my garage to have a look at that?
thanks.
Last edit: 29 Nov 2015 11:23 by BenoMosko.
29 Nov 2015 11:41 #157463 by facade
Not exactly. Suzukis don't leak oil as a rule, that is why they go so rusty.
They will leak if someone has taken them apart, and not replaced the seals, or if those pipes are blocked (unlikely though)
BenoMosko wrote: What exactly should i need to tighten? cam cover gasket (What is that?)
The gasket is a rubber seal between the two parts, (pink line) you should find that the leak is coming from this area and running down.
Do not tighten anything, you will only make it worse, get the gasket/seal changed if you want.
BenoMosko wrote: and how can i check that the black hosepipes leading to the top of the engine are not blocked?
Squeeze the tabs on the metal clips together, and the clip will expand and slide along the pipe, then the pipe twists and pulls off. Check that the metal part is clear, and that the pipe is not full of material.
The grey valve pulls outwards, and should rattle if you shake it. It has a one way valve inside.
BenoMosko wrote: should i contact my garage to have a look at that?
I would clean off the oil, and see how much leaks out in a week say. If it takes a long time to look like the picture, I wouldn't bother. If it is leaking enough that you have to add more oil, have it fixed.
  • BenoMosko
02 Dec 2015 08:43 #157704 by BenoMosko
Thank you so much.
You helped a lot!!!
