Can i use m18a throttle body and intake manifold ?
29 Nov 2015 04:42 #157438
by Mr.m.y
Can i use m18a throttle body and intake manifold ? was created by Mr.m.y
Hi
I have finish swap my engine m13a not vvt with m18a vvt
The engine run great
but i replace m18a throttle body and intake manifold with m13a
It seem m18a has bigger throttle body and intake manifold
There is any problem if i replace it ?
What about the vacuum line for the hub ?
29 Nov 2015 08:12 #157442
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Can i use m18a throttle body and intake manifold ?
I know the m16a will fit but the car doesn't idle correctly. Very fast idle. I read somewhere that you can swap the jimny idle control valve over and this cures the problem. However I haven't tried.
Grey pick up Jimny
The following user(s) said Thank You: Mr.m.y
- saboor73
29 Nov 2015 08:21 #157443
by saboor73
Replied by saboor73 on topic Can i use m18a throttle body and intake manifold ?
Swap it I am sure you are using m18a ecu if yes than swap it fast idle issue only occur with m13aMr.m.y wrote: Hi
- saboor73
29 Nov 2015 08:23 #157444
by saboor73
BTW without original trottle body your aren't really enjoying the power of m18a
29 Nov 2015 12:02 #157465
by Rhinoman
Replied by Rhinoman on topic Can i use m18a throttle body and intake manifold ?
You need to fit the M13A idle speed controller to the M18 throttle body, there is a post explaining how to do this on Auszookers.com here:
www.auszookers.com/forum/viewtopic.php?f=17&t=30308&start=180
29 Nov 2015 14:15 #157476
by Mr.m.y
Replied by Mr.m.y on topic Can i use m18a throttle body and intake manifold ?
thank you all
What about the m18a intake ?
It dose-not have vacuum line for the hub
I want the number or code or name for ECU M18a vvt and m13a vvt
Time to create page: 1.283 seconds
