Advice on best location for a light bar
  • NineCherries
16 Nov 2015 21:49 - 16 Nov 2015 21:58 #156443 by NineCherries
Advice on best location for a light bar was created by NineCherries
Ok, I fancy a light bar on my Jimny but I'm weighing up the pros and cons regarding fitting location.
I'm considering roof mount (ideally on the leading edge of a roof rack) or in the bumper recess. What one is better?
I presume the roof position will give you a better spread of light as it will have a better angle in relation to the road surface, yeah?
Opinions please :) Tia
Last edit: 16 Nov 2015 21:58 by NineCherries.
  • Steveolkinevel
16 Nov 2015 22:17 #156446 by Steveolkinevel
Replied by Steveolkinevel on topic Advice on best location for a light bar
If it's right on edge of roof over windscreen you won't be able to see as it will make your windscreen turn white with light so mount it back about 6-8" then it's bang on with no probs.
17 Nov 2015 00:25 #156458 by Busta
If the lights are below your eye level, you can see the shadows projected by rough ground and dips in the road, helping you read the road ahead. It's much harder to judge the terrain with lights above your eye level because you can't see the shadows they cast. This is why car headlights are where they are, not on the roof! For night stages, rally cars use bonnet pods rather than roof bars for this reason.
Try shining a torch across some uneven ground while holding it above your head, then down by your waist and you will see the difference.
The following user(s) said Thank You: NineCherries
  • NineCherries
17 Nov 2015 09:41 #156470 by NineCherries
Replied by NineCherries on topic Advice on best location for a light bar
I never thought of that, both replies were useful, thanks.
  • Steveolkinevel
17 Nov 2015 17:55 - 17 Nov 2015 17:57 #156497 by Steveolkinevel
Busta wrote: If the lights are below your eye level, you can see the shadows projected by rough ground and dips in the road, helping you read the road ahead. It's much harder to judge the terrain with lights above your eye level because you can't see the shadows they cast. This is why car headlights are where they are, not on the roof! For night stages, rally cars use bonnet pods rather than roof bars for this reason.
I guess VW didn't know this when they built and designed the touraq?? :dry: Or Nissan with the xtrail.
Last edit: 17 Nov 2015 17:57 by Steveolkinevel.
  • wombat
17 Nov 2015 18:26 #156503 by wombat
Replied by wombat on topic Advice on best location for a light bar
I guess VW didn't know this when they built and designed the touraq?? :dry: Or Nissan with the xtrail.[/quote]
Why, did they come with roof lights as standard ?
Time to create page: 0.602 seconds
