Advice on best location for a light bar
- NineCherries
I'm considering roof mount (ideally on the leading edge of a roof rack) or in the bumper recess. What one is better?
I presume the roof position will give you a better spread of light as it will have a better angle in relation to the road surface, yeah?
Opinions please
- Steveolkinevel
Try shining a torch across some uneven ground while holding it above your head, then down by your waist and you will see the difference.
- NineCherries
- Steveolkinevel
Busta wrote: If the lights are below your eye level, you can see the shadows projected by rough ground and dips in the road, helping you read the road ahead. It's much harder to judge the terrain with lights above your eye level because you can't see the shadows they cast. This is why car headlights are where they are, not on the roof! For night stages, rally cars use bonnet pods rather than roof bars for this reason.
I guess VW didn't know this when they built and designed the touraq?? :dry: Or Nissan with the xtrail.
- wombat
Why, did they come with roof lights as standard ?
