What would tractor tyres on a jimny break?
- mkay
18 Oct 2015 19:03 #153878
by mkay
What would tractor tyres on a jimny break? was created by mkay
I have a offroad only jimny to getting around the fields at the farm basicly its my UTV.
If I put a 10" wide x 28.7" od tractor tyre on the back and a Mud terrain with the same OD on the front.
Is this liable to break something?
- Thank you received: 1869
19 Oct 2015 06:28 #153896
Replied by Lambert on topic What would tractor tyres on a jimny break?
It would entirely depend on how heavy your right foot is. If you are just creeping about solo and unloaded on gentle grass pasture then yes it is going to put some extra strain on the transmission but you should be fine, if you are raching about loaded up or with a trailer on the back and are constantly giving it beans through a heavy plough soil then yeah all sorts of things will get broken like cv joints, transfer boxes, half shafts all sorts of carnage.
- mkay
19 Oct 2015 09:14 #153900
by mkay
Replied by mkay on topic What would tractor tyres on a jimny break?
Thanks for the reply.
Is the likelihood of damage due to the increased weight/surface area/increased traction?
For the most part it is just driving through damp/wet fields to check on stock, in summer we tow a 300l bowser and carrying about fencing materials to remote locations.
Have to be heavy footed with the odd gateway that the tractor has messed up but certainly far from gung ho.
More than anything just wanting to lower ground pressure.
- mkay
19 Oct 2015 14:24 #153903
by mkay
19 Oct 2015 15:18 #153912
Sounds a lot like what I do with mine save for I don't go on the land between November ish and March ish so I use the standard bridgestone tyres to good effect.
The thing that destroys components is when the wheels spin and then when they find traction suddenly it's the shock loading that snaps things. Big meaty tyres will reduce the initial risk of slipping over a road or all terrain but that is off set by the severity with which they grab if they do spin.
- mkay
19 Oct 2015 15:41 #153915
by mkay
Would just having them on the rear help as there are no steering components so the wheels are directly on the Axel?
Time to create page: 2.736 seconds
