Jimmy 2003 Dohc timing marks and crank pulley nut
- Johntom
05 Oct 2015 17:32 #153037
by Johntom
Jimmy 2003 Dohc timing marks and crank pulley nut was created by Johntom
Hi
I'm attempting head gasket replacement on my 2003 Jimmy DOHC.
I've spotted a small notch on the crank pulley but are there any timing marks on the camshafts/cam sprockets ?
Also the crank pulley has to come off to remove the timing chain cover, any tips on removing it?
Thanks
Thanks
05 Oct 2015 17:41 #153039
by facade
The traditional way is to put a ring spanner on it, with the free end wedged under the chassis rail on the drivers side, then blip the starter.
You might find this difficult with the cam chain dangling, so plan b is to jam the flywheel ring gear somehow from underneath through the tinplate cover on the bell housing.
Plan C is to make up some sort of tool as I believe there are bolt holes in the inner pulley for just such a situation.
Always crack the crank pulley nut before you take the engine apart if you know you want the pulley off.
IIRR Ed China has a special levery spanner thingie that engages the teeth.
Replied by facade on topic Jimmy 2003 Dohc timing marks and crank pulley nut
Johntom wrote: Hi
Thanks
- Johntom
05 Oct 2015 17:47 #153042
by Johntom
Replied by Johntom on topic Jimmy 2003 Dohc timing marks and crank pulley nut
Hi
I have removed the inlet and exhaust manifolds but the cam chain is still untouched. Will the force from the starter motor crack the nut or does the engine need to start for a second ?
- mickt
05 Oct 2015 18:17 #153044
by mickt
Replied by mickt on topic Jimmy 2003 Dohc timing marks and crank pulley nut
Isolate the ign and fuel. If you have a impact gun then 17mm socket and bingo, with the rad out of course. I did my daughters fan belt(again) on Sunday and changed the pulley and used a new bolt to refit. Took about one hour, but the sun was shining!
- Johntom
09 Oct 2015 06:36 #153282
by Johntom
Hi
Does anyone where the fuel pump fuse or relay are on a 2003 1.3 dohc ? Can't find anything labelled as such in the fuse box under steering wheel or under the bonnet
09 Oct 2015 06:49 #153283
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Jimmy 2003 Dohc timing marks and crank pulley nut
Fuel pump relay is at the side of the battery and down a bit. 2 relays one for the starter one for the fuel pump, fuel pump has the pink wire to it
Grey pick up Jimny
Time to create page: 0.211 seconds
