Jimny not level after hitting hill too hard
  • GraphicX
29 Sep 2015 06:44 #152708 by GraphicX
thanks in advance for any assistance :)
basically went up this hill really hard;
that's a vid of me doing it with a locker, i tried again without the locker & pushed too hard (still couldn't get over it) & it threw my steering right out (steering wheel was pointing over toward 10-11 o'clock).
had a wheel alignment done & it appears i've slightly bent an axle/diff housing, but apparently it's not awful (car drives nice again). issue is my passenger side rear is now sitting 22mm higher than the driver's side & the passenger's side front is about 15mm higher than the other side.
i've checked & all the springs appear to be seated correctly, also the panhard rods etc appear straight too (but i'm yet to hold a straight edge against them).
beyond checking those i'm really lost as to what the issue could be, so please ... help ... me ...
29 Sep 2015 16:32 #152734 by facade
Try parking facing the other way, and see if the lean moves to the other side.
Seriously, my Jimny leans terribly on the drive, so much so that I was looking to put a spacer under the drivers rear spring, but park it on a level surface, or put it on the MOT ramps, and it is perfectly level. I would never have thought the miniscule slope on the drive (I didn't know I had one) would make such a difference.
You may find that it is nothing to do with bending it, just you've never looked for the problem before.
The following user(s) said Thank You: GraphicX
  • darthloachie
29 Sep 2015 23:05 #152770 by darthloachie
Replied by darthloachie on topic Jimny not level after hitting hill too hard
If it all checks out ok then get a single Spring spacer from either jimnybits or bits4vits and fit it to the drivers front Spring to level it out. It's a common problem on Rhd Jimnys as the driver and battery are on the same side of the car
  • GraphicX
30 Sep 2015 00:08 #152774 by GraphicX
Replied by GraphicX on topic Jimny not level after hitting hill too hard
@ facade; never thought to check in another direction, will give it a look.
@ loachie; it has always had a lean, but previously in the other direction :S
spoke to the mechanic who did the wheel alignment, apparently a shock mount has begun to tear away & he's confident the housing is bent. i just didn't think it'd cause the car to sit so strangely.
  • GraphicX
03 Oct 2015 08:23 #152905 by GraphicX
just a quick update on this for anyone who may encounter a similar issue.
i've torn a front lower shock mount, but it appears i did it a while back. the main issue appears to have been the shocks came unseated & needed twisting in their mounts. the car isn't perfectly level, but appears to have the typical jimny lean so i'm happy with it again.
thanks darth & facade for your suggestions.
Time to create page: 0.150 seconds
