Broken coil spring - big job to change?
  • The Dug
22 Sep 2015 16:59 #152377 by The Dug
The jimny failed it's MOT today with a broken OSF coil spring (and rear brake efficiency).
Problem is I go back offshore soon and don't have time to do it myself before I go so if it's a big job I'm thinking just get a local garage to do it then resubmit for MOT while I'm away.
Any thoughts?
22 Sep 2015 18:57 #152388 by Rhinoman
Front spring should be pretty simple if the front shock mounts will come undone, I don't recall having to undo anything else to drop the spring out. The rear could be a seized handbrake cable, pistons or just shoes, none of which are that difficult to do. Even f you were to put it into a garage it shouldn't be more than a couple of hours labour.
The following user(s) said Thank You: The Dug
  • Statey
23 Sep 2015 08:24 #152407 by Statey
Replied by Statey on topic Re:Broken coil spring - big job to change?
Just be carefully of stretching the brake pipe when dropping the axle
Time to create page: 0.148 seconds
