Sump oil leak
- gus2000
12 Sep 2015 11:51 #151796
by gus2000
Replied by gus2000 on topic Sump oil leak
12 Sep 2015 11:54 #151797
by facade
Replied by facade on topic Sump oil leak
You may be lucky, but as I said, the one thing Suzuki can do well is seal joint faces, there is no sump gasket just RTV sealer. Don't overtighten the screws, they are only 10Nm, which is a tweak with a 1/4 socket wrench. If you overtighten, they just distort the face of the sump, and it does leak then.
Check the oil isn't coming from higher up on the engine and running down, the O ring seal at the back of the single cam is favourite, otherwise the cam cover if it has been disturbed (there is a gasket here).
- gus2000
12 Sep 2015 12:28 #151800
by gus2000
- Sprocket
12 Sep 2015 20:16 #151858
by Sprocket
Replied by Sprocket on topic Sump oil leak
Thanks for all the tips. I'll let you know how it goes.
- phillw
30 Sep 2015 18:22 #152803
by phillw
Replied by phillw on topic Sump oil leak
Hi, I was just wondering how you were getting along with this as I too have recently discovered that my sump is porous and has developed a pretty decent leak in the last couple of weeks. Its a 52 plate. Would a new sump be easy to get hold of from Suzuki for this year? I presume its a pretty easy fix as long as i can get hold of a sump..
01 Oct 2015 08:20 #152817
by facade
Suzuki will sell you one, but the price will make you cry.
They are very difficult to get second hand, as they are all rusty, and breakers won't take the sump off a good engine if they think they can sell the whole engine.
If you have time, take it off, and clean it up, you can braze a patch over any pinholes on the inside, then finish the outside with leak-fix.
However, even a minute leak left and oil will weep out.
Time to create page: 0.258 seconds
