Underseal- what's the best?
- adamatdraycott
03 Sep 2015 21:53 #151281
by adamatdraycott
Replied by adamatdraycott on topic Underseal- what's the best?
Dinitrol is the stuff you want. It seems to be the preferred treatment in the LR world
04 Sep 2015 15:59 #151316
by Rhinoman
Replied by Rhinoman on topic Underseal- what's the best?
I'll cast a vote for Hammerite with Waxoyl as well, its good stuff, I find it better than the regular bitumen underseals which can peel. I don't know if the usual Waxoyl places will apply it or just the Waxoyl spray, its worth spraying the insides of the panels and chassis.
04 Sep 2015 16:03 #151317
by Rhinoman
Hammerite with Waxoyl is an underseal rather than a hammered paint.
philpridd wrote: in my opinion.wickes hammered paint is better then hammerite
- Johnniehec
- Thank you received: 56
04 Sep 2015 20:16 #151338
by Johnniehec
Replied by Johnniehec on topic Underseal- what's the best?
Another vote for Dinitrol from me.
- Venter
04 Sep 2015 21:16 #151341
by Venter
Replied by Venter on topic Underseal- what's the best?
Johnnie, I seem to remember you're up in NE Scotland... Where is there around these parts that will do an underbody seal with the above products?
05 Sep 2015 10:25 - 05 Sep 2015 10:30 #151357
by facade
Replied by facade on topic Underseal- what's the best?
Mine is smothered in dinitrol, doesn't seem to work.
Over the past 35 years I have tried everything, and once you have rust, nothing stops it*. You have to get all the rust off to bare metal, then etch prime (if you can find any etch primer old stock, the new stuff doesn't etch) paint with good paint, then stone chip or underseal to protect the surface, and waxoyl over that.
The "best" results I get are by wirebrushing/sanding/grinding off the rust, and painting with Aldi anti-corrosion metal paint (poor man's chassis black/smoothrite) Every time I get underneath I attack any rusty streaks/bubbles with a scraper, and daub more on.
I thought I'd found something that might work: Fertan. :woohoo:
I was looking at Gosport submarine musem, and how they conserved the Holland 1, after fishing it out of the water.
Experts treated it with anticorrosion chemical, that I found was Fertan, but it soon went as rusty as old iron and no paint would stick again. So they had another go themselves and soaked it for 4 years in a tank of washing soda. The problem is chloride ions from salt, which obviously came from the sea for Holland 1, but we get them courtesy of "The Council" :S
*Whether I've held it back is debatable, there is no untreated control to check against. Certainly the box sections under the headlights that got a good dosing of dinitrol clear on the inside, and black on the outside, have continued rotting out.
Last edit: 05 Sep 2015 10:30 by facade.
Time to create page: 2.535 seconds
