Lower Front Suspension Bracket broken !
- John_S_RAA
- Senior Member
- Thank you received: 1
12 Aug 2015 20:50 #149708
by John_S_RAA
Lower Front Suspension Bracket broken ! was created by John_S_RAA
Helped set up and running Ultra4 Europe King Of Wales off road event at Walter Arena in Wales. Jimny performed great towing trailer tent to campsite and then getting around the site. Only needed a tug once to get out of a deep rutted track which had left me beached. On the journey back to Hampshire I was feeling pleased with the handling until about 1/2 hour from home when I detected a slight knocking noise and handling was no longer so precise.
Upshot is the lower front suspension bracket has broken on nearside.
Is a replacement bracket available?
Does anyone do an uprated bracket?
Cheers for replies.
Better go and find my bike now to enable me to get to work. (Only 3.5 miles but its all uphill !!!!!!)
Cheers for replies.
13 Aug 2015 09:45 #149728
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Lower Front Suspension Bracket broken !
A photo of the broken part will really help here to get more advise.
- John_S_RAA
- Senior Member
13 Aug 2015 19:58 #149775
by John_S_RAA
Replied by John_S_RAA on topic Lower Front Suspension Bracket broken !
Here are a couple of photos. (sorry about quality but you can get the gist of things!)
13 Aug 2015 21:22 #149779
by Jezz
You can either have that re-welded. Or have a new mount made and welded on. Or as a last resort change the axle tube.
I'd have it re- welded and beefed up at the same time.
- Thank you received: 923
14 Aug 2015 07:30 #149785
Replied by X8GGY on topic Lower Front Suspension Bracket broken !
These might help -
www.jimnybits.co.uk/shop/jimny/bumpers-/...ounts/prod_1473.html
Once the original bracket is re-welded...
The following user(s) said Thank You: John_S_RAA
14 Aug 2015 09:06 #149786
Replied by mlines on topic Lower Front Suspension Bracket broken !
Offroad Armory used to do the brackets as you can see from my own repair
www.bigjimny.com/index.php/bigjimny-blog...211-brackets-v15-336
However these were discontinued. I believe he will cut some if the group order is big enough but not one offs.
Time to create page: 0.196 seconds
