Oil Leak Front End - Newbie in need of help
  • Hardy2712
06 Aug 2015 21:14 #149258 by Hardy2712
Replied by Hardy2712 on topic Oil Leak Front End - Newbie in need of help
Jimny-Dave wrote: The front diff slides into the axle casing like this -
And there is a seal of mastic between the two faces, it may be leaking from there, or simply from the oil drain hole / plug on the bottom of the axle casing, there does seem to be a lot of oil around it in your photo...
I'd start by tightening the 8 bolts around the back of the diff and the oil drain plug, clean the oil off with some old rags and see after a while if it's still leaking.
You'd better top your diff oil up a bit too?
Oil syringe makes it easier...
Hope that helps...
Dave ;)
That's a massive help. Thanks very much. What oil do I top it up with?
06 Aug 2015 21:16 #149259 by X8GGY
The following user(s) said Thank You: Hardy2712
  • Hardy2712
06 Aug 2015 21:18 #149261 by Hardy2712
cheers mate. Really appreciate it.
06 Aug 2015 21:23 #149263 by X8GGY
I added another photo above with the diff bolts arrowed... try tightening them to see if any are slightly loose, that's what my problem was...
Off out now, happy to help...
Dave
Time to create page: 0.391 seconds
