Damage to rear prop shaft
- Brave
25 Jul 2015 05:17 #148379
by Brave
Damage to rear prop shaft was created by Brave
Hi All,
Just a quick question, is it common after lifting your Jimny for the rear prop shaft to fail (at the Universal joint).
We took may friends Jimny out the other day, first time off-roading and half way into the trip his rear prop failed. The was not even hard just a few logging trails.
I am thinking of increasing my lift from a very sagged 2"to a possible 4". Has anyone else had the same issue?
Thanks
Thanks
- Decklandpt
25 Jul 2015 05:32 #148383
by Decklandpt
Replied by Decklandpt on topic Damage to rear prop shaft
erm...didn't you fit the spacer after the lift?
- Brave
25 Jul 2015 05:54 #148385
by Brave
Replied by Brave on topic Damage to rear prop shaft
Spacer gets fitted to front not back
25 Jul 2015 06:47 #148386
by Busta
Replied by Busta on topic Damage to rear prop shaft
The universal joints will wear out over time. Lifting the car means they are working at a greater angle than they have previously, so may cause a tired joint to fail. A new joint or one in good condition should be fine though.
- Brave
25 Jul 2015 07:25 #148387
by Brave
Thanks busta. So you think I'll have no problems with a 4" lift kit
Time to create page: 0.187 seconds
