Fixed the beep and the heater
  • spandit
20 Jul 2015 14:57 #148057 by spandit
Fixed the beep and the heater was created by spandit
I quite like sitting in my Jimny listening to the radio, for which I need the ignition on, but unless the key is turned enough to power the fuel pump etc., the annoying beep sound comes into play.
I took the gauges out and on the back was a black plug. I took this out to see what would happen and the beeping disappeared - can't see any other effects as yet but easy enough to replace should it cause problems later on.
I then thought I'd try the heater out, which I hadn't used since buying the Jimny last month. Took a while to figure out why there was no hot air coming out but eventually found the wire had come off the control and that's now reinstalled. It was then that the blower just stopped suddenly. I checked and replaced the fuse to no avail but then nudged a bundle of wires under the steering column - the blower came back on again. Further inspection found that someone has fitted an immobiliser at some stage (which I think is now bypassed) using those awful Scotchlok connectors and it has been arcing and got so hot that the plug is melted, so replacing the wiring is not going to be easy. It's been cut so close to the plug that I had little option but to tape up the connector and hope for the best.
  • mickt
20 Jul 2015 19:27 #148081 by mickt
Replied by mickt on topic Fixed the beep and the heater
If it is overheating then tape will not stop it. A fire is a possibility!
  • JimnyGlenn
20 Jul 2015 20:38 #148094 by JimnyGlenn
Replied by JimnyGlenn on topic Fixed the beep and the heater
If your not sure take it to a good auto spark. Horses for courses mate. Forums aren't the best places for electrical problems. I'm a Domestic / Commercial / Industrial spark and I go to more problems through forums than anything else. No disrespect to anyone on here as there are some very knowledgeable people but if the advice is interpreted wrong and the actions are carried out incorrectly then you could cause yourself or others a serious accident. Please don't think I am being patronising, just a good bit of advice ;)
  • helijohn
20 Jul 2015 21:01 #148100 by helijohn
Replied by helijohn on topic Fixed the beep and the heater
JimnyGlenn wrote: If your not sure take it to a good auto spark. Horses for courses mate. Forums aren't the best places for electrical problems. I'm a Domestic / Commercial / Industrial spark and I go to more problems through forums than anything else. No disrespect to anyone on here as there are some very knowledgeable people but if the advice is interpreted wrong and the actions are carried out incorrectly then you could cause yourself or others a serious accident. Please don't think I am being patronising, just a good bit of advice ;)
Strange how car electrics frighten a lot of people including mechanic mechanics.
I've always found good electrics advice on forms though.
  • spandit
20 Jul 2015 21:43 #148123 by spandit
Replied by spandit on topic Fixed the beep and the heater
I'm quite au fait with vehicle electrics, but thank you anyway. This was a repair in the field, the Scotchlok is now on a better connection and squeezed tight (it was loose before) with tape to hold it closed - I'll get a proper crimp in there in due course...
Time to create page: 0.291 seconds
