non working 4 wd after fitting avm jumny hubs
  • philpridd
14 Jul 2015 10:57 #147745 by philpridd
hello all,have just fitted avm manual hubs to my 2008 Jimny,only to find that though the hubs are set to 4x4,not only is the green light flashing,but its not in 4 wheel drive either,whem hubs set to 4x4,and one wheel jacked up,the wheel can be rotated juat like in 2 wd,seems as though the gearbox will not go into 4 wd unless the vacuum system is working,or have I missed something,all the vacuu pipes are still connected,and with the old vacuu hubs back in place,the 4 wd is working again,help please.
14 Jul 2015 11:08 #147747 by j999pre
You will need to trick the control unit into believing the vacuum system is working.
You may be able to do this by linking the 2wires to the vac sensor under the vacuum solenoids below the battery. Black and white wires I think
Can I ask why your fitting manual hubs if your vac ones work?
Cheers
Grey pick up Jimny
The following user(s) said Thank You: philpridd
  • helijohn
14 Jul 2015 16:35 #147764 by helijohn
Replied by helijohn on topic non working 4 wd after fitting avm jumny hubs
Cheers
I think I would as a matter of course James simply because you know they will be there when needed, everytime. I did mine as the previous owner reported them not being reliable.
14 Jul 2015 18:51 #147771 by j999pre
I always thought that John but a mate that did his jimny up the same time me still uses vac hubs and had no probe, one the problems stay that would be time to swap in my book.
Grey pick up Jimny
15 Jul 2015 16:54 #147803 by Basketcase
I've only recent changes from vac hubs because I was at a p&p and forgot to unblock the pipes after the kingpins had gone and they got sludged up so modified it to permenant vac but that really messed the system so now using hubs I've 'manufactured'. If the vac system is working leave it working. Don't fix what isn't broke
16 Jul 2015 20:09 #147847 by Rhinoman
Time to create page: 0.308 seconds
