ignition key will not turn
- toms dun
14 Jul 2015 10:06 #147743
by toms dun
ignition key will not turn was created by toms dun
used my 2000 Jimny last night fine! came to start this morning and key won't turn .As if I'm using someone else's keyCan anyone help please Thought might be my key had a problem so tried wife's the same
Cheers
toms dun
Cheers
toms dun
14 Jul 2015 11:10 #147748
by j999pre
Grey pick up Jimny
Replied by j999pre on topic ignition key will not turn
I had this a while back and I took the cowl off and have the steering look a gentle tap with a hammer! This worked. However I have had this on 2other jimnys and ended up putting a lock set on them!
Grey pick up Jimny
The following user(s) said Thank You: toms dun
- toms dun
14 Jul 2015 11:19 #147749
by toms dun
Replied by toms dun on topic ignition key will not turn
Thank you worked a treat
16 Jul 2015 20:11 #147848
by Rhinoman
Replied by Rhinoman on topic ignition key will not turn
It may help if you run a little light oil down the key into the lock.
- toms dun
16 Jul 2015 20:51 #147855
by toms dun
The thin Oil bit I tried almost straight away didn't do a thing think something has broke inside barrel Have had to use hammer technique several times since.Can Just the barrel be replaced?
Where might I get A complete lock set and what sort of price am I Going to have to pay
16 Jul 2015 20:57 #147857
by j999pre
Grey pick up Jimny
If you replace just the barrel you will be on a different key from the door locks and will have to take your old key to the key reader to get past the immobiliser
A full lock set would mean your back to just one key but again would need to fool the immobiliser with your old key
Final option is lock set and ecu
Which engine and body style is yours ie g13b or m13a? Hard top or soft top?
I have locks and barrel for m13a
I also have a lock set and ecu etc for a g13b hard top
Grey pick up Jimny
Time to create page: 1.753 seconds
