Jimny- newbie questions and upgrading the shocks
  • hora
13 Jul 2015 10:28 - 13 Jul 2015 10:33 #147693 by hora
Hello, I'm new. Go easy on me :)
I've got a question- to stop the 'bounce'- I guess its a sort of fidgerty(?) ride that happens on the road. Are there specific shock(s) that you can fit aftermarket that help calm this? I dont need offroad shocks etc and I know dropping the tyre psi's helps a bit.
Anything else? Thank you.
Ps- interms of costs what to expect and.... anywhere garagewise that you'd recommend in the NWest (Manchester).
Last edit: 13 Jul 2015 10:33 by hora.
13 Jul 2015 10:44 #147694 by j999pre
It could be you old shocks have had it? If so just get new replacements. Check them for oil leaks and maybe remove the bottom bolts and test for resistance/damping
Grey pick up Jimny
  • TomDK
13 Jul 2015 14:22 #147695 by TomDK
hora wrote: Hello, I'm new. Go easy on me :)
It may just be a matter of putting new shocks on. The old ones could be worn out.
In that consider Koni shocks. They are probably around the same price as original Jimny shocks, but a far better ride :)
14 Jul 2015 07:07 #147734 by Busta
The Jimny is a small, lightweight car with a high unsprung mass (heavy wheels and axles), so it will always feel fidgety on the road compared to most things! It could be down to worn shocks, but it could just be because that is how they are...
  • hora
27 Jul 2015 15:04 #148516 by hora
Thanks guys :)
Another question - is it possible to space out the wheels (increase the track) to aid stability - i.e. with standard shim spacers (or do you need to do abit more work on it to make it effective). I was thinking by about 10-20mm overall if possible?
Ps. I love tinkering with cars :D
  • Decklandpt
27 Jul 2015 15:30 #148519 by Decklandpt
Replied by Decklandpt on topic Jimny- newbie questions and upgrading the shocks
mine have always felt "jumpy". a friend of mine says it's like a nervous chiuahua.
the petrol one even more so, because it's lighter.
but i notice that with both cars, after a while i stop noticing it. at first it's like the shocks are rock solid, but after a while you start to feel them a lot softer. it's just a matter of getting used to it.
you can add spacers to it (in my country the MOT's are very much against them, so you have to make it stealthy), but you can also replace the rims for a set or rims with some offset.
personally, i dont feel much at ease with that becuse i fear the extra width on standard axle will exert too much pressure on the axle and bend or break something
Time to create page: 0.170 seconds
