Too much snatch !!!
  • gusthegorilla
27 Jun 2015 17:12 #146714 by gusthegorilla
Too much snatch !!! was created by gusthegorilla
:) And no, I'm NOT going to elaborate ;)
2006 VVT , electronic transfer box.... when changing from 1st to 2nd, and 2nd to 3rd, very noticeable clunk when taking up the drive, despite changing gear extra smoothly.
Changed the rear engine (gearbox) mounting, no difference
Changed t/box and rear diff oil, no difference. However, on removal of diff drain plug, large quantity of grey coloured filings attached to the magnet.
Holding rear drive shaft and intermediate drive shaft and turning against each other...tight as a drum!!
Where SHOULD I be looking , guys...I'm clearly missing something :sick:
Thanks a lot,
Gus :)
27 Jun 2015 18:57 #146721 by kirkynut
Replied by kirkynut on topic Too much snatch !!!
Does the rear diff have much slack in it? Hold the prop and turn quickly to feel if the diff turns like you tested the uj's.
Or have you kind of done that when checking the uj's?
The following user(s) said Thank You: gusthegorilla
  • gusthegorilla
27 Jun 2015 19:50 #146725 by gusthegorilla
Replied by gusthegorilla on topic Too much snatch !!!
Tried that with both shafts separately, and there is what I would call "some free play", couldn't decide whether it's at the diff end or the t/box end, that was the reason for locking one shaft against the other.
Tested individually, there's what I imagine to be excessive free play in both.
Is there another way of locking out each one individually, so I might make a decision based on "process of elimination??
Thanks, Kirkynut,
Gus :)
27 Jun 2015 22:22 #146734 by facade
Replied by facade on topic Too much snatch !!!
gusthegorilla wrote: However, on removal of diff drain plug, large quantity of grey coloured filings attached to the magnet.
If it is just grey slime, no worries. If it is metal filings and bits of teeth, problems.
You have checked that the axle can't roll nose up/down because the two trailing arm bolts on each side have worn through/ovalled the holes/snapped the plates off/worn the rubbers out?
Diff flange doesn't move sideways/up & down?
With the handbrake on in neutral turn the propshaft, if there is more than 1/4 turn of free play in the propshaft the diff is worn.
Wheelnuts are tight? (seen it :ohmy: )
Exhaust pipe cant hit anything? if the engine moves, or if the axle moves?
28 Jun 2015 06:05 #146743 by kirkynut
Ah, facade has probably sussed it. I don't know why I didn't think of it considering I've not long solved the same on mine! Rear radius arm bolts need nipping up a bit!
  • gusthegorilla
28 Jun 2015 08:51 - 28 Jun 2015 08:55 #146746 by gusthegorilla
Well that's taken me by surprise, facade !! If I measured the rotational slack using a protractor, it's no more than 5 degrees....and I thought that was a lot. From what you say, there is NO wear in my diff, just normal free play.
The grey slime on the drain plug resembled the very finest valve grinding paste, so again, I don't think the problem is there either.
So the obvious one is as you suggest....the radius arms/bushes/holes, etc.
Kirkynut seems to agree, so thank you both for that...will give it a look.
Gus :)
EDIT Don't know what happened here with the "quote" ....sorry!!
Last edit: 28 Jun 2015 08:55 by gusthegorilla. Reason: typo
Time to create page: 0.154 seconds
