Steel wheels with offset for the Jimny
16 Jun 2015 10:09 #146061
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Steel wheels with offset for the Jimny was created by Mike G
Hi Folks,
Been trawling the internet looking for a new set of steel wheels with a -30 offset. Couldn't find any on bigjimny.com, jimnybits.com or bits4vits. I did however find these:
Suzuki Vitara wheels
Does anyone know if or what the offset is on these compared to standard jimny wheels? I've emailed the seller about them, but would prefer an opinion from the experts.
16 Jun 2015 10:45 #146062
by Mike G
Replied by Mike G on topic Steel wheels with offset for the Jimny
Ok, so I got a response from the seller:
"These will be ET 0. This would mean you have 4" of wheel coming out from the hub
These are for off road set ups normally and are not meant to be a copy of the original setup in anyway"
So, I now know ET0 means 'no offset' in German. But these wheels are meant for a Vitara. Has anyone bought these and fitted them. I'd love to get an opinion on these. I've emailed about the centre bore size. Shouldn't think that would be a problem with a wheel for a Suzuki tho..... :pinch:
- oxford_bloke
16 Jun 2015 11:28 #146064
by oxford_bloke
Replied by oxford_bloke on topic Steel wheels with offset for the Jimny
I have the grand vitara 16" wheels fitted with 235/85/16 fitted, with 4.5 and 2 inch lifts and have no problem with them. Had to trim the arches and fit fender flares but did this using caravan arch rubber
16 Jun 2015 12:50 #146068
by Mike G
Nice. I'm sticking with the 15" to keep the wheel mass down and as I'm only putting in a 2" lift, I'm having to be a little conservative with my ideas. That and my wallet wont keep up with the pace. :pinch:
Do you have any pics of your arches? I'd like to see the flaring. My Jimny is an 07, so I'm probably going to be stuck with keeping the original bumper, so I may have to do a bit of shaving, depending on the size of boots that go on it.
16 Jun 2015 13:24 - 16 Jun 2015 15:19 #146069
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Steel wheels with offset for the Jimny
I've some black modulars 5 of 15 x 7j with 215 75 15 General grabbers x5 all about 6 months old. One is new. Loads of tread and the wheels are in great condition and the offset is just wide enough to push the wheels to the edge of the arch
£350
£350
Grey pick up Jimny
Last edit: 16 Jun 2015 15:19 by j999pre.
16 Jun 2015 14:56 - 16 Jun 2015 14:57 #146075
As j999pre mentioned they should look like this when fitted
These have an offset -30 on an 07 plate
Replied by Daniel30 on topic Steel wheels with offset for the Jimny
j999pre wrote: I've done black modulars 5 of 15 x 7j with 215 75 15 General grabbers x5 all about 6 months old. One is new. Loads of tread and the wheels are in great condition and the offset is just wide enough to push the wheels to the edge of the arch
£350
Last edit: 16 Jun 2015 14:57 by Daniel30. Reason: added text
Time to create page: 0.352 seconds
