Check engine light problems at low mileage
- Lazia23
12 Jun 2015 13:27 #145858
by Lazia23
Check engine light problems at low mileage was created by Lazia23
Going down the road this afternoon the check engine light has come on. all sounds good except that when i come off the throttle the revs falter at 1100 rpm ever so slightly before returning to idle.
Its not audible when driving but clear enough when running the engine still. a few pops from the exhaust as well.
only done 44,000 miles as well so that isn't right.
any ideas?
any ideas?
12 Jun 2015 15:13 #145862
by Rhinoman
Replied by Rhinoman on topic Check engine light problems at low mileage
It is 14 years old. You should pull the fault codes to see where the issue lies.
- Grego
12 Jun 2015 16:32 #145865
by Grego
Replied by Grego on topic Check engine light problems at low mileage
Got the Engine light on on mine at 10yrs old and 17,000 miles ,age and mileage is irrelevant .Similar symptoms as you described, read code that pointed to throttle body, cleaned inside and all good.
The Eml can come on anytime
- Lazia23
12 Jun 2015 16:45 #145867
by Lazia23
Replied by Lazia23 on topic Check engine light problems at low mileage
i've read the codes and is showing ECU failed. i take it that that's a new ECU then? i wll have to see what the garage says on monday.
12 Jun 2015 20:35 - 12 Jun 2015 20:36 #145887
by facade
Replied by facade on topic Check engine light problems at low mileage
There's a code for "ECU failed"? :ohmy:
What is the actual code number displayed?
I would have thought that if the ECU had failed the engine wouldn't run, and it wouldn't be possible to communicate with it.
EDIT: Was it "communication failed"?
Last edit: 12 Jun 2015 20:36 by facade.
- Lazia23
13 Jun 2015 11:14 #145918
by Lazia23
well according to the link posted on the forum a few years ago if you jump the pins and the engine warning lights stay constant then it means ECU failure. i don't have a code reader so i can't be sure for certain
Time to create page: 0.138 seconds
