rocklobster oil grade
- gaz3359
28 Apr 2015 09:51 #143313
by gaz3359
rocklobster oil grade was created by gaz3359
Hi just a quick one what grade oil do people reccomend for a lobster ive currently got ep90 in with a dolop of molly grease ive ran it for a couple hundred miles and want to change it just with the box i got been sat about a bit.id read somewhere to run a thicker grade ? Also wheres best to get these oils my normal suppler cant get the mineral type oils anymore.cheers
- TomDK
28 Apr 2015 10:50 #143320
by TomDK
Replied by TomDK on topic rocklobster oil grade
GL5 oil.
- Thank you received: 683
28 Apr 2015 11:46 #143327
Opie oils
Replied by jackonlyjack on topic rocklobster oil grade
gaz3359 wrote: Hi just a quick one what grade oil do people reccomend for a lobster ive currently got ep90 in with a dolop of molly grease ive ran it for a couple hundred miles and want to change it just with the box i got been sat about a bit.id read somewhere to run a thicker grade ? Also wheres best to get these oils my normal suppler cant get the mineral type oils anymore.cheers
Opie oils
- gaz3359
28 Apr 2015 11:58 #143333
by gaz3359
Replied by gaz3359 on topic rocklobster oil grade
Had a read through daves jimny build see what he used sorted.
- Rockwatt
29 Apr 2015 06:33 #143387
by Rockwatt
Replied by Rockwatt on topic rocklobster oil grade
Ep90 classic hypoid
GL5 is to thin and not needed for the sj box as there is no yellow metals in them 'ie syncros'
I personally use ep130 from commercial supply for extra protection but for off road only
