Alternator (or the belt) still squealing.
09 Jan 2015 18:50 #134682
by facade
Hot is because it is slipping.
If it slips when tight then the grooves in the pulleys are the wrong shape for the belt, or the alternator is seizing.
The pulley gets pretty hot too.
Apparently common with old age for the alternator stator to fall apart and jam the rotor, although I'd never encountered it before, that s what the guy at the autoelectricians told me was wrong with mine, you could unseize it by turning it backwards, then it would spin fine until you put it back on the car...
Replied by facade on topic Alternator (or the belt) still squealing.
The Dug wrote: [( and VERY hot)
The following user(s) said Thank You: The Dug
- The Dug
10 Jan 2015 11:25 #134726
by The Dug
Replied by The Dug on topic Alternator (or the belt) still squealing.
Looks like I just had the belt too loose - tightened up with my engineering multi-tool (big hammer). Now seems to be fine, got green light on the battery charge and no squealing.
Time to create page: 0.346 seconds
