Suzuki Jimny Specifications
- Russ-41
05 Jan 2015 21:19 - 05 Jan 2015 22:15 #134258
by Russ-41
Behind the Headlight, its got right thought the steel, almost to the base of the lip, I'm not sure if I'll bother welding a bit in there as its possibly causing water to pool, I'll probably just cut it out and seal it, perhaps weld a rod or mini angle across if it feels weak.
The rust paint/tar can be seen on the left, down the length the sill looks ok I think?
Not looking so clean and nice since I took the nieces and nephews for a crawl round my parents land, including over the muck heap....... what was I thinking? its been rotting down for 5-10 years and its full of powdery white crap, I can only assume its mould....... like I said, what the f*&$ was I thinking :S I just saw something big and thought, I'll crawl over that.......
EDIT*
The black spot on the fuel tank protector, and the larger one to the left of the prop shaft are the remains of flung diff oil - I need to work out which size seal I have and get that done ASAP, is there anyway I can tell without taking it off (measure diameter of shaft?)
Replied by Russ-41 on topic Suzuki Jimny Specifications
EDIT*
Last edit: 05 Jan 2015 22:15 by Russ-41.
- Russ-41
05 Jan 2015 22:01 - 05 Jan 2015 22:16 #134266
by Russ-41
Boot floor almost completely spotless, 1 little spot of paint starting to raise in the middle of the passenger side slope down in to the jack well, about the size of a 5p piece, should I be looking elsewhere?
There are also 2 light, but larger, >50p piece size symetrical spots under the rear seats.
kirkynut wrote: It's not the chassis you need to worry about but the boot floor, sills and behind the head lamps!
Get a piccie up then so we can see it!
Last edit: 05 Jan 2015 22:16 by Russ-41.
06 Jan 2015 21:26 #134339
Hear hear.
I live by it.
Replied by helijohn on topic Suzuki Jimny Specifications
facade wrote:
Russ-41 wrote:
Wikipedia is the source of most online nonsense.
Don't diss Wikipedia: it is the repository of the sum of all Human Knowledge. :ohmy:
I gave them £5 this year to keep going add free
Hear hear.
06 Jan 2015 21:38 #134342
I always try to prevent a chassis from rusting from the inside out. I swear by Waxoyl though there are others just as good.
That's a tasty bit of tinworm in that first picture.
Russ-41 wrote: I just can't believe how clean the chassis is - regardless of age.
I really should take steps to keep it that way (perhaps have it coated in something?)
Time to create page: 0.272 seconds
