Upgraded heavy duty clutch kit???
  • davert85
17 Dec 2014 10:13 #132580 by davert85
Upgraded heavy duty clutch kit??? was created by davert85
Hi all,
As you may or may no know from a previous post, i have a suspected broken clutch.
What im wondering is, is there any upgraded, heavy duty, uprated off road clutch kits, flywheels etc out there that i can get which will hopefully reduce my chances of this happening again.
If there is whats the cost and where from?
Any info would be great thanks chaps.
David
  • GuardianAngel
17 Dec 2014 10:23 #132582 by GuardianAngel
Replied by GuardianAngel on topic Upgraded heavy duty clutch kit???
Execdy clutches work well, I have one fitted to my J and I do a lot of laning etc. You can find them in the BJ shop here: www.bigjimny.com/store/index.php?_a=product&product_id=201
As for flywheels, the standard flywheel on a Jimny is fine. All you need to do is make sure that if you have burnt out your clutch that there are no scorch marks on it, which can cause cracks and high spots. I had to replace my flyweel as mine had a couple if high spots which would cause uneven wear on the new clutch if not changed.
  • davert85
17 Dec 2014 11:09 #132588 by davert85
Replied by davert85 on topic Upgraded heavy duty clutch kit???
GuardianAngel wrote: Execdy clutches work well, I have one fitted to my J and I do a lot of laning etc. You can find them in the BJ shop here: www.bigjimny.com/store/index.php?_a=product&product_id=201
Thanks pal. I did look at those but iv got a soft top so wont fit. Any other suggestions??
Thanks.
  • GuardianAngel
17 Dec 2014 11:40 #132592 by GuardianAngel
j999pre wrote: All clutches fit all jimnys apart from the diesel
The BJ shop states the Excedy clutch only fits non-Spanish models so I guess that pretty much equates to the soft-tops. Not saying your are wrong, but it might be worth checking out.
  • darthloachie
17 Dec 2014 13:45 #132604 by darthloachie
Time to create page: 0.561 seconds
