Drilling rear bottom shock mounts
08 Dec 2014 22:05 #131895
by kirkynut
Replied by kirkynut on topic Drilling rear bottom shock mounts
Cheers chaps - what's the reason for them sheering though - I can only think it's a direct hit from a rock or similar or seized in and sheering when being undone?
Cheers
Cheers
- supergaz
09 Dec 2014 21:41 #131979
by supergaz
Replied by supergaz on topic Drilling rear bottom shock mounts
Either impact or fatigue, hell of alot of stress goes through them, especially off road.
10 Dec 2014 07:07 #131987
by robs5230
standard jimny - for now
Replied by robs5230 on topic Drilling rear bottom shock mounts
you need a couple of good quality 12mm bits i think i used piranha. and some kind of coolant / cutting paste. a drill with some guts makes it easier too. nice and slow and let the drill and bit do the work . took me about 20 minutes per side. careful breaking through the other side as the bit may nip up and snap. i think they shear on a lifted jimny ( non caster corrected) as the shock sits at such a bad angle over the bolt putting loads of pressure on one area. even standard ones i have seen are at an angle.
10 Dec 2014 21:48 #132028
by kirkynut
Thanks again chaps. I've been playing with brake pipes and diff breathers so haven't done anything yet and was considering whether I shall do so or not, using the info you have all supplied to assist in making a decision.
Robs5230, you make interesting points about fatigue and angles.
Mine have been abused in the past but not failed once. This was with no castor correction with a 3" lift too.
Now I have Castor Correction and new bolts. We shall see. It is certainly easier to do it now than when a bolt is sheared off inside!
I grease them with waterproof grease on the bolt threads regularly and carry spare bolts, should one come out, but do them up with my electric impact gun, so they are unlikely to do so and never have.
I shall have a think!
13 Dec 2014 23:40 #132284
Hey Rob, have you finished thinking? :whistle:
Replied by helijohn on topic Drilling rear bottom shock mounts
kirkynut wrote: I shall have a think!
16 Dec 2014 14:39 - 16 Dec 2014 14:40 #132463
by kirkynut
Nope! It hurts and I've just had a stroke! Not another one, the original one!
:S
:S
Last edit: 16 Dec 2014 14:40 by kirkynut.
Time to create page: 0.380 seconds
