Broken my Ariel today :(
  • Tomhorntoad
07 Dec 2014 17:37 #131760 by Tomhorntoad
Broken my Ariel today :( was created by Tomhorntoad
As above ... Broke my blasted Ariel on over hanging trees Etc green laning in Pevensea, Sussex
Are they east to replace?
  • suzook
07 Dec 2014 17:56 #131762 by suzook
Replied by suzook on topic Broken my Ariel today :(
Hi,
They are very easy to replace. Just unscew your old one and pull it out a few inches. Cut it off from the top BUT ensure you attach your new cable end using electrical tape or gaffer rape to the end to form a temprary join. Then from the bottom find the wire and pull your new cable and plastic sheath down and when the new cable comes out connect it to the connecting block by your brake pedal. Then screw the 2 x screws into he top and your all done. Its easier if there are 2 people - 1 pulling the cable down at floor level, the other guiding the new sheath down from the top.
It is quite a tight squeeze by the pedals - but can be done easily. :)
  • hunter1084
07 Dec 2014 19:54 #131779 by hunter1084
Replied by hunter1084 on topic Broken my Ariel today :(
Its easy I done it by myself I just unplugged it at the radio, tied abit of string to the end, un done the screws and pulled it out.
Then tie the string to the end of the new aerials cable and pull it back through. Easy :)
07 Dec 2014 20:23 #131787 by facade
Replied by facade on topic Broken my Ariel today :(
The "correct" approach is to take the broken off bit and ram it into the socket. so you have a 6" ariel that will only get local stations ;)
Mine has been like that since I got it, several years ago :laugh:
The following user(s) said Thank You: Tomhorntoad
07 Dec 2014 20:47 #131790 by Halford
Replied by Halford on topic Broken my Ariel today :(
if you've CB you could get a Zetagi DX27 CB Radio Car Stereo Splitter Box CB Radio
don't know what they're like :huh:
07 Dec 2014 23:11 #131798 by kirkynut
Replied by kirkynut on topic Broken my Ariel today :(
Halford wrote: if you've CB you could get a Zetagi DX27 CB Radio Car Stereo Splitter Box CB Radio
They are good. I have one. Bought it from Thunderpole and someone kind posted a 10% discount code for them the other day!
