Sucking noise from filler cap
  • rexthecat
22 Nov 2014 11:06 #130326 by rexthecat
Replied by rexthecat on topic Sucking noise from filler cap
I think what's happening with mine is a build up of the vacume, I know it's quie common to get that hiss when you undo the cap, I get that too but when it's been running a while and I park its a noticeble noise. So I'm guessing maybe it's the vaulve in the cap that's sticking as that's the one that should let air into the system?
I noticed you can get new ones for £10, do you reckon they have the valve? They seem to be listed for the jimny
Cheers
22 Nov 2014 11:32 #130328 by facade
Can't you take your cap apart?
I bet it is just a rubber flap that has welded itself to the lid.
I'll have a look at mine if it ever stops raining here :)
  • helijohn
22 Nov 2014 19:54 #130369 by helijohn
Replied by helijohn on topic Sucking noise from filler cap
facade wrote: There is a one way valve in the cap, that allows air into the tank, to prevent the tank sucking flat. It should prevent fuel coming out of the cap if the car falls over. I've never noticed mine hissing, but I don't stand next to the filler when it is running.
The fuel system is sealed, to prevent fumes reaching the atmosphere.
When it gets warm, and the fuel expands, it fills up the expansion space in the tank and there is a pressure valve in the small vent line that opens and allows vapour into the charcoal cannister next to the alternator.
The cannister is vented via a short rubber pipe to the air, and the charcoal holds the fuel vapour.
Next time the engine starts, air is drawn in through the charcoal cannister to the inlet manifold, purging all the vapour back to the engine.
If you overfill the tank, by shaking the car and filling right up the spout, on a hot day liquid fuel gets in the charcoal cannister, and this does cause a problem at the next start up when the cannister is purged.
The vapour control nicely explained!! ;)
Those charcoal gizmos are expensive to replace and I think the whole system is OTT - paranoia.
There is a cap-in-bits thread I did somewhere on here.
  • idiotmobil
23 Nov 2014 20:44 #130466 by idiotmobil
Replied by idiotmobil on topic Sucking noise from filler cap
Im not 100% but i think mine done that but i just ignored it
