Body lift dimensions
- Wuzie123
12 Nov 2014 17:15 #129321
by Wuzie123
Body lift dimensions was created by Wuzie123
Hey can anyone tell me the size of the internal hole and the extrnal size of a 2" body lift block? Going to machine up a set for the jimny....
- Basketcase
- Thank you received: 51
12 Nov 2014 17:48 #129325
by Basketcase
Replied by Basketcase on topic Body lift dimensions
One of my mates is helping me do a body lift on ours we found a 13mm hole should for the standard body bolts through make sure you undo all the bolts before trying to fit the lift under any part, it's so much easier they're 14mm bolts apartfrom the ones just in front of the rear wheels which are 17mm, have fun!
- Wuzie123
13 Nov 2014 16:16 #129412
by Wuzie123
Replied by Wuzie123 on topic Body lift dimensions
Thanks basketcase but I'm still looking for the outside dimension of the Body lift spacer so I can machine some out of polyurethane...
Anyone?
Anyone?
- Thank you received: 923
13 Nov 2014 16:24 - 13 Nov 2014 16:28 #129413
Replied by X8GGY on topic Body lift dimensions
Most are 2" / 50mm OD, but the body mounting puck is 3" / 75mm in diameter, hence why I make my (Vitara/GV) ones out of poly, and the same diameter and shape as a body mounting puck, only tallerer...
So -
So -
Last edit: 13 Nov 2014 16:28 by X8GGY.
- Wuzie123
13 Nov 2014 20:45 #129433
by Wuzie123
That's great thanks
13 Nov 2014 22:18 #129456
Welcome, hope it helps...
Time to create page: 2.273 seconds
