where is the gearbox filler bolt
- mark 88
10 Nov 2014 09:17 #129095
by mark 88
where is the gearbox filler bolt was created by mark 88
hi all ive noticed a slight weep from my drain bolt so I thought id check how much was in. I can see something that maybe the filler just below the breather its a hexagonal bolt that looks like a 20mm socket would fit it.
any help would be great thanks all
- mc_nebula
10 Nov 2014 10:24 - 10 Nov 2014 22:17 #129100
by mc_nebula
Replied by mc_nebula on topic where is the gearbox filler bolt
It's up high, about half way up, drivers side. It's an [strike]11mm [/strike] 10mm square, like the diff. You can get away with a 3/8 ratchet though. You will need a giant oil syringe thing to fill it though.
www.machinemart.co.uk/shop/product/detai...ose-oil-transfer-syr
Last edit: 10 Nov 2014 22:17 by mc_nebula.
10 Nov 2014 11:16 #129105
by kirkynut
I think it's 10mm.
Replied by kirkynut on topic where is the gearbox filler bolt
mc_nebula wrote: It's up high, about half way up, drivers side. It's an 11mm square, like the diff. You can get away with a 3/8 ratchet though. You will need a giant oil syringe thing to fill it though.
I think it's 10mm.
- mickt
10 Nov 2014 11:19 #129106
by mickt
Replied by mickt on topic where is the gearbox filler bolt
I used my 3/8 ratchet and filled a oil can with its own finger pump that you use on lathes and the like to fill mine.
- mark 88
10 Nov 2014 17:06 #129132
by mark 88
Replied by mark 88 on topic where is the gearbox filler bolt
that's great everybody thanks
- auchenblae
- Elite Member
- Thank you received: 25
10 Nov 2014 22:07 - 10 Nov 2014 22:09 #129189
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic where is the gearbox filler bolt
On the 8 Valve car the fill point is was on the offside of the gearbox.
On our 2007 car is is on the nearside of the gearbox and in both cases a pain to get at.
It is requires a 10mm square key to remove and I have rounded the socket on one of those plugs using a 3/8 square. Luckly on the front diff that was easy to get a chisel to fix it.
It is not worth the risk of saving some money and not buying a 10mm socket.
On the other hand cash now is always king to some people over the cost of getting things out whn you have rounded the socket.
As always it's your choice.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Last edit: 10 Nov 2014 22:09 by auchenblae. Reason: typo
Time to create page: 2.586 seconds
