how to i wire up my spot lights to my main beam
- Jimnyjack1993
06 Nov 2014 19:42 #128740
by Jimnyjack1993
how to i wire up my spot lights to my main beam was created by Jimnyjack1993
need help on how to wire my spot lights to my main beams instead of a switch
thanks jack
thanks jack
- Thank you received: 683
06 Nov 2014 19:48 #128743
Replied by jackonlyjack on topic how to i wire up my spot lights to my main beam
use a scotch lock to connect to main beam wire then put your spot earth wire to car body/negative on battery
- Jimnyjack1993
06 Nov 2014 19:53 #128747
by Jimnyjack1993
Replied by Jimnyjack1993 on topic how to i wire up my spot lights to my main beam
will i need a relay?
06 Nov 2014 20:25 #128761
Are your spots led or halogen and how many you wanting to light up at one time
- Jimnyjack1993
06 Nov 2014 21:27 #128769
by Jimnyjack1993
led and 4 lights at 5amp each, the mains are on a negative feed tho
07 Nov 2014 09:22 - 07 Nov 2014 09:35 #128798
by kirkynut
Replied by kirkynut on topic how to i wire up my spot lights to my main beam
Yes you need a relay and it wires up in the usual way except it is switched on the earth not the live.
If you are unsure, get a relay with a diagram on it's box from Halfords or somewhere and understand you need a permanent live to the relay activation not a switched one and an earth that goes to the earth wire of one of the main beam bulbs.
If you have fogs already you have a relay already. So then it's just a case of running a wire from the earth of one main beam bulb to the earth of the activation pins on that relay.
Last edit: 07 Nov 2014 09:35 by kirkynut.
Time to create page: 0.579 seconds
