bit of smoke on startup
05 Oct 2014 08:19 #125764 by robs5230
for a while now, every now and again i get a puff of smoke on startup. its just gone through the mot with good emissions pass and theres no smoke whilst running. there does seem to be a little oil in the bottom of the air filter box from time to time.
i have seen odd posts when searching about engine oil stop leak products and i'm wanting to know whether anyone has used these long term and if they would fix this ?
cheers rob
standard jimny - for now
  • Reloaded
05 Oct 2014 08:41 #125767 by Reloaded
Replied by Reloaded on topic bit of smoke on startup
Try that Blue Devil stuff, search on ebay - I can't post a link at the moment. It's good shit :)
  • Reloaded
05 Oct 2014 12:21 #125786 by Reloaded
No eBay APP ID and/or Cert ID defined in Kunena configurationIf it's valve stem seals it's this product you want...
05 Oct 2014 20:21 #125824 by robs5230
Replied by robs5230 on topic bit of smoke on startup
cheers lads i'll order some
  • Biasmechanic
05 Oct 2014 21:28 #125835 by Biasmechanic
Replied by Biasmechanic on topic bit of smoke on startup
Something similar was mentioned in another topic recently. The consensus was that its a Jimny quirk to smoke on start up if its been previously started but not warmed up. I did the same and assumed something was wrong as mine would regularly blow a fair bit of smoke on start up but it randomly stopped a few months ago. After reading the other topic I realised the smoke stopped about the same time I stopped having to move the Jim every time some one else wanted to go out. Seems if they get shut off before they get off start up enrichment they over fuel on next start up. Might just be this in your case?
  • helijohn
06 Oct 2014 18:57 #125885 by helijohn
Replied by helijohn on topic bit of smoke on startup
robs5230 wrote: cheers lads i'll order some
I've been an advocate of this for a long time.
bigjimny.com/index.php/forum?view=topic&...imitstart=0&start=12
