g16b into a jimny - what parts do I need
- darthloachie
03 Sep 2014 09:23 #123286
by darthloachie
g16b into a jimny - what parts do I need was created by darthloachie
- Cider
03 Sep 2014 13:49 #123296
by Cider
Replied by Cider on topic g16b into a jimny - what parts do I need
- darthloachie
03 Sep 2014 19:38 #123316
by darthloachie
Replied by darthloachie on topic g16b into a jimny - what parts do I need
Thanks Pete
03 Sep 2014 19:56 #123321
by j999pre
Grey pick up Jimny
Replied by j999pre on topic g16b into a jimny - what parts do I need
I bought the adapter and engine mount from water babies.
Swap your crank pulley
Inlet manifold but use the gv injectors
Swap mounts. Also water pipe from rear of pump. Make a little bracket.
Power steering tensioner has a few solutions. Done lower the bottom 2 holes on a plate. Others just chop the top bit off so it just mounts with the lower holes. I use the lower holes and re weld the top piece to pic up the top hole.
Water feeds for heater and your about there
The adapter I used was for the sj so needed the bottom on each side cutting off
Grey pick up Jimny
The following user(s) said Thank You: darthloachie
- darthloachie
04 Sep 2014 12:35 #123364
by darthloachie
Thanks James
- darthloachie
12 Sep 2014 18:23 #123958
by darthloachie
Time to create page: 0.249 seconds
