g16b into a jimny - what parts do I need
  • darthloachie
03 Sep 2014 09:23 #123286 by darthloachie
g16b into a jimny - what parts do I need was created by darthloachie
Hi all
Just bought a g16b engine out of a grand vitara gv1600 thats done 54k which comes complete as in the picture
what do I need to fit it into my g13b jimny?
do i need a gearbox adapter plate? if so where from?
what do I need to keep from the jimny engine?
thanks in advance
Chris
  • Cider
03 Sep 2014 13:49 #123296 by Cider
  • darthloachie
03 Sep 2014 19:38 #123316 by darthloachie
Replied by darthloachie on topic g16b into a jimny - what parts do I need
Thanks Pete :)
03 Sep 2014 19:56 #123321 by j999pre
I bought the adapter and engine mount from water babies.
Swap your crank pulley
Inlet manifold but use the gv injectors
Swap mounts. Also water pipe from rear of pump. Make a little bracket.
Power steering tensioner has a few solutions. Done lower the bottom 2 holes on a plate. Others just chop the top bit off so it just mounts with the lower holes. I use the lower holes and re weld the top piece to pic up the top hole.
Water feeds for heater and your about there
The adapter I used was for the sj so needed the bottom on each side cutting off
Grey pick up Jimny
The following user(s) said Thank You: darthloachie
  • darthloachie
04 Sep 2014 12:35 #123364 by darthloachie
Thanks James :)
  • darthloachie
12 Sep 2014 18:23 #123958 by darthloachie
hi guys
how do I identify a skinny starter?
is it either of these?
Time to create page: 5.338 seconds
