Rear lock right locker
- supergaz
29 Jul 2014 06:47 - 29 Jul 2014 06:49 #120908
by supergaz
Replied by supergaz on topic Rear lock right locker
I reused the original shim and not the new supplied shim and mine works perfect. The supplied shim is known to be too thick.
That was installed by myself and has covered 5000 road miles and still works perfect.
Last edit: 29 Jul 2014 06:49 by supergaz.
- TomDK
29 Jul 2014 21:33 #120978
by TomDK
The reason why it does not make much sense what you're writing, is that the supplied washes go on the inside of the side gears. The Shims are used on outside. Also, the washer supplied with the kit is much much thicker than the shims. So can't really see how the shims replace the washers.
Replied by TomDK on topic Rear lock right locker
supergaz wrote: I reused the original shim and not the new supplied shim and mine works perfect. The supplied shim is known to be too thick.
- supergaz
30 Jul 2014 17:49 #121055
by supergaz
TomDK, there is a simple fitting guide with pictures somewhere out there on the internet that I followed a few years ago that I cannot find again
I remember not using some new supplied shims/washers as they were too thick, this was in the instructions not to use the supplied shims when fitting to a jimny diff.
Time to create page: 0.275 seconds
