Gearbox Filler & Oils
  • C-U-JIMNY
01 Jun 2014 18:19 #116834 by C-U-JIMNY
Gearbox Filler & Oils was created by C-U-JIMNY
Having difficulty getting oil into the gearbox? here's a inexpensive tip for filling the gearbox oil,
get a length of rubber hose about 28" long 1/2 OD and about 5/16" ID, remove a filler nozzle from one of the plastic 1 litre filler bottles, cut the threaded part off the top of the plastic tube and push this into the hose, from under the bonnet just behind the rocker cover feed the hose down and insert into the gearbox filler hole, connect the other end of the adapter to the bottle and screw it on invert the bottle and fill to overflow.
gearbox oil is TRX Synthetic 75 w 90 ( miller ref 5252) gearbox holds 1.1 litres Transfer box has the same oil 1.34 litres.
Both Diffs are 80/90 GL5 (miller ref 5219) front 1.35 Litres, rear 1.5 Litres
Engine 5 w 30 (miller ref 5995) 4.3 litres
- See more at: www.bigjimny.com/index.php/forum?view=to...sthash.WVicOKJY.dpuf
Time to create page: 0.149 seconds
