Is this the right oil for front and rear diffs?
30 May 2014 13:28 #116658
by minibbb
Is this the right oil for front and rear diffs? was created by minibbb
- Thank you received: 115
30 May 2014 13:40 #116662
by maverick
Jalapeño, IISY?
Replied by maverick on topic Is this the right oil for front and rear diffs?
looks good to me ... as i change my Diff and T-Case oils every other month - i also buy 'generic' 80/90 Oil.
Jalapeño, IISY?
30 May 2014 13:46 #116665
by minibbb
Replied by minibbb on topic Re:Is this the right oil for front and rear diffs?
Cheers buddy, bought it ages ago but read elsewhere I needed GL5 and that GL4 was only for the gearbox
Sent from my iPad using Tapatalk
30 May 2014 13:51 - 30 May 2014 13:52 #116666
by facade
Replied by facade on topic Is this the right oil for front and rear diffs?
It should be GL5 for the axles.
There are less anti-wear additives in gl4, but likely you won't notice any difference, get GL5 next time.
75/90 gl4 in the gearbox, those extra additives can damage the yellow metals used for synchronisers and bushes in a gearbox.
Last edit: 30 May 2014 13:52 by facade.
The following user(s) said Thank You: minibbb
30 May 2014 13:55 #116668
by minibbb
Hmmm reckon I should just change it before I do the job? High mileage car so should have the proper stuff really
30 May 2014 14:24 #116678
by facade
If it was me, I'd stick that in the front diff, as I don't use 4wd much, and get a couple of cans of GL5 for the rear one that turns all the time.
(If you can swap it for GL5, do- BTW you need 3 bottles to change front & rear diff oils, the rear holds just enough so there isn't quite enough left in the second bottle for the front :pinch: )
Time to create page: 2.770 seconds
