Noise when flexing off road
18 May 2014 18:35 #115630 by Rhinoman
Check the routing of the handbrake cable - it could be pulling on at full flex.
18 May 2014 21:55 #115670 by Johnniehec
topjimny wrote: I got a click click when flexin and solved tighten my radius arms nuts.
Radius arm to axle bolts, holes in axle brackets will be starting to elongate, mine have and that's where the clicking comes from
  • Bits4Vits
18 May 2014 22:02 - 18 May 2014 22:03 #115673 by Bits4Vits
Replied by Bits4Vits on topic Noise when flexing off road
Rhinoman wrote: Check the routing of the handbrake cable - it could be pulling on at full flex.
I noticed when lifting mine 3" that the handbrake cables are tight (happens on Vitaras which is what I'm used to), so during the lift I have taken the loops off the handbrake cables where they bolt on next to the radius arm to chassis joint, and then positioned the loop behind the lump in the cable instead of in front... hard to explain, I'll get a photo tomorrow...
It's common on highly lifted Vitaras for the droop on the rear axle to make the handbrake cable go taut and apply the brakes as a result, causing premature [strike]ejac[/strike]... brake wear!
Last edit: 18 May 2014 22:03 by Bits4Vits. Reason: Too many beers, can't string a sentence together!
  • Millzy
18 May 2014 22:52 #115676 by Millzy
Replied by Millzy on topic Noise when flexing off road
Ok cool so I'll have to have go at tighten the radius arm nuts tonight ? Could some one explain as I am a complete ametuer and don't know much about Jimmy's but gotta start somewere I guess also I have no idea what saying about handbrake ??? I did see some people raise that spring that sitting on the rear diff does that have something to do with it !!!!
Time to create page: 2.725 seconds
