Creeky stearing
  • Tommo
07 May 2014 17:53 #114389 by Tommo
Creeky stearing was created by Tommo
It has only just started, the steering is Creeky when I turn
Sharply, I've sprayed oil on all the joints on the
Steering shaft, Basicly every thing I can see of it
Under the bonnet, but it still does it, any ideas?
Any one else has this problem
07 May 2014 18:13 #114394 by kirkynut
Replied by kirkynut on topic Creeky stearing
Kingpin bearings shot or very dry from not being greased is my initial thought.
It could be a tie rod end though.
It's tricky to tell without being able to look at it.
07 May 2014 20:56 #114410 by facade
Replied by facade on topic Creeky stearing
Most likely kingpin bearings as Kirkynut says. Mine did it really loudly when parking until I changed them.
  • Tommo
08 May 2014 06:42 #114435 by Tommo
Replied by Tommo on topic Creeky stearing
It now seems to be quite noticeable,
The noise coming from the front off side wheel.
But that kingpin was only changed just under a year ago?
That is the newer one of the pair
  • Tommo
08 May 2014 10:46 #114454 by Tommo
Have a look at this video
I'm on my phone so I can only
Upload to Facebook at the mo
m.facebook.com/JACKASS92
08 May 2014 22:11 #114540 by kirkynut
Sorry mate but I'm not on BookFace.
I'm still putting my money on a kingpin bearing but could be a wheel bearing or tie rod end.
Have you had it up on axle stands and investigated yet - if not, you'd be better doing so or we're just throwing wild guesses at you!
Sorry I'm not much help but I can't see we'll diagnose it online without you having a proper look see.
It could even be a knackered suspension bush with the bolt grinding in the crush tube, heck there's too many possibilities!
Time to create page: 2.103 seconds
