Tail shaft CV joint diagnosis?
03 May 2014 21:34 #114055
by kirkynut
Replied by kirkynut on topic Tail shaft CV joint diagnosis?
You're right - I can't find a How To Guide either but I'm sure I've seen one, so I've no idea where that's gone!
You can get them from car spares shops, no need to get one from Suzuki!
- Squilookal
12 May 2014 04:44 #114912
by Squilookal
Replied by Squilookal on topic Tail shaft CV joint diagnosis?
Hmmm, finally got under the car and had a look at this. There’s no grease point in the UJ’s, so unfortunately I can’t do anything there but there’s no play at all in the tail shaft (or propshafts) and no visible signs of anything untoward in any of the UJ’s .
Given that the noise that was there for about 2 weeks and was diagnosed as a tailshaft UJ has been gone for nearly 3 months now, does anyone have any thoughts on the original diagnosis and what to do about replacing this?
- jonesyba420
12 May 2014 06:46 #114916
by jonesyba420
Replied by jonesyba420 on topic Tail shaft CV joint diagnosis?
The UJ isnt greasable the rear prop itself has a greese nipple tho.
Suzuki will try take you for a mug, if they cant supply the uj go elsewhere.
If its gone away and you cant find anything wrong id just leave it alone and see if the noise returns.
- Squilookal
16 May 2014 23:27 - 17 May 2014 03:57 #115470
by Squilookal
Thanks jonesyba420, that's pretty much what I thought too.
I've finally worked out that that noise comes back for a while after reversing uphill to our parking spot rather than driving in. To test the theory, I reversed all the way up the drive the other day and the chatter on overrun was back plus quite a bad deep vibration whilst accelerating.
Does any of this help anyone with a diagnosis?
Thanks again to everyone who's helped out with this - it's starting to drive me a little crazy!
Last edit: 17 May 2014 03:57 by Squilookal.
Time to create page: 0.332 seconds
