M13A crank pulley wobble
  • GuardianAngel
27 Apr 2014 15:35 #113490 by GuardianAngel
M13A crank pulley wobble was created by GuardianAngel
I noticed yesterday after fitting a new fan belt and radiator that the bottom crank pulley has a slight wobble.
I have read some threads which seem to suggest that the pulley has a rubber damper which might be failing?
So if it does need changing, are they difficult to remove and refit?
  • jonathan
27 Apr 2014 16:18 #113491 by jonathan
Replied by jonathan on topic M13A crank pulley wobble
most of them you undo the bolt holding them then pull them off ,most have a keyway to put them in the right place
  • Chazg83
29 Apr 2014 19:26 #113728 by Chazg83
Replied by Chazg83 on topic M13A crank pulley wobble
GuardianAngel wrote: I noticed yesterday after fitting a new fan belt and radiator that the bottom crank pulley has a slight wobble.
Mine broke this morning haven't taken off yet but when I do let ya know,
  • Chazg83
29 Apr 2014 19:27 #113729 by Chazg83
Called main dealer aswell £161 lol
  • rs200boy
29 Apr 2014 21:31 #113752 by rs200boy
Replied by rs200boy on topic M13A crank pulley wobble
done mine few months ago as above wasnt cheap think they were £135 on ebay
my centre nut was solid had a power bar on it jammed it an quick flick on starter cracked the thread lock bolt came out no problem after
  • Chazg83
29 Apr 2014 22:00 #113764 by Chazg83
rs200boy wrote: done mine few months ago as above wasnt cheap think they were £135 on ebay
Ok cool I'll keep it in mind, I got a snap on impact gun just hope it does it if not I'll give it a try, when you put the bolt back did you use thread lock? Cheers
Time to create page: 0.241 seconds
